1 - 8 of 8 Posts
WV hillbilly
Id like some advice/opinions on my current project and a HP questimate..
383 CID 12.5:1 CR
Pro Topline 220CC alum heads (machined for 2.055x1.60) gasket matched to fel-pro #1206 chambers polished, exhaust fully ported, Intake bowls blended 64CC chambers
Edelbrock # 2925 (super Victor) intake blended and portmatched
Lunati solid roller 297/305 264/272 .640/.642 106
850 holley DP w/ 2" super sucker spacer
1 3/4 hooker super comp longtubes ( possibly a slight restriction)
this motor will be in a 2800 LB 84 notchback mustang
Trans will be a TH350 w/ a coan 4200 stall 4.30 rear gear
Motor Plate application, Electric water Pump, manual steering , the only thing ill be turning is the alternator..
the oil pan is a Moroso #710-20191 (jegs) w/ built in windage tray..
so what kind of power should I make? and what do you hotrodders think it will turn in the 1/4?
Thanks, 2wld4u
WV hillbilly
Discussion Starter · #4 · (Edited)
they flow real close to the advertised flow #'s out of the box they flow'ed @ 28" 4.060 bore 2.05X1.60
.100 64 51
.200 118 101
.300 170 130
.400 210 158
.500 242 178
.600 260 192
I havent had them flowed after the potwork but my machinest said they flow the advertised #'s and possible a lil more now...
the portwork was preformed due to the #'s being slightly off the advertised specs, I'll get them flow'ed again before I assemble the longblock, but that wont be untill at least another week or so...
WV hillbilly
maybe somone can Desktop Dyno this set up for me? ( I no longer have a dyno program) dyno numbers out of the box will ease my tension a lil... anyone?
Hey 2wld4u, I loaded up the specs you listed and came up with these numbers for you combo.
615hp @ 7000RPM
520 tq @ 5500RPM
I can probably fine tune them a bit with a little more clarification of the cam specs and some other stuff if you want, but these should give you an idea.:thumbup:
WV hillbilly
615hp @ 7000RPM
520 tq @ 5500RPM
:drool:
hey thanks!
p.s the cam is a Lunati Roller the part # 638-50144 (jegs)
I dont have a cam card, this was the cam I was thinking of using with my combo, I could possibly get more info on the cam, ( Jegs tech guy's are really cool about that stuff) just name what youd like and ill see if I can get the specifics...
Well 2Wild4u, I went with a few assumptions on the cam to get the numbers for you.
I set the Lobe center angle at 106 (Cam Degrees) - Assumed
I set the Intake Duration at 276.0 (Crank Degrees) - From your Post
I set the Intake Centerline at 102 (Crank Degrees) - Assumed
I set the Exhaust Duration at 284 (Crank Degrees) - From your Post
Then I set the valve lifts at 640 / 642 also from your post.
This gave me IVO (BTDC) @36 / IVC (ABDC) @60
EVO @ 72 (BBDC) / EVC @ 32 (ATDC)
I figured these were pretty close to accurate, but if you can get the cam card or the specifics from Jegs, then that would work perfect.
1 - 8 of 8 Posts
