1 - 7 of 7 Posts
will a cam change effect the shift point on auto trans?
before i changed cam, trans (w/shift kit) would hit hard on 1-2 shift
now it shifts lighter
p.s. also have adjustable vac modulator
engine will idle down to 700-800 in gear about 850-950
in park
seems to run ok, slight surging below 2500 rpm
thanks
R.
Premium Member
Well, surging quite often indicates a leak :welcome: . Do a check with some carb cleaner or whatever you prefer to use. What were your old cam specs vs. your new ones?
Race it, Don't rice it!
Surging on light throttle also indicates a lean carb if no vacuum leaks are detected. A conditon of booster signal at the carb caused by a longer cam.
Discussion Starter #4
new cam is comp cam XE268
old cam was isky 2800-6000 rpm.
lift was higher than new one
(measured lobes to check lift- to see if springs would handle new cam, just a double check i did check for coil bind)
thanks
R.
just checked plugs.....they are white
time for jet/rod kit.
Premium Member
Before you tear into the carb do a check for leaks. It will cause a system to run lean as well.
One thing you can do to check for leaks that`s a little cleaner is use a propane torch, start the engine, turn on the propane, and go around the carb and intake with it, if there`s a leak the engine will pull in the propane and the idle will go up.
Premium Member
I like to attach a hose on the end of my propane so that I can further pinpoint the leak. It makes it easier to get behind the engine to (incase the leak is towards the back of the manifold and whatnot).
1 - 7 of 7 Posts
