Hi guys. Newbie on this forum. I’m doing some mods on my ‘59 ‘Vette. we built a strong SBC w/Super T-10. Then attached and adjusted Vertical Gate shifter. I haven’t started the engine yet, so the tranny gears haven’t turned very much. The shifter works smoothly but finding neutral is a problem. There is no positive “signal” indicating neutral. There is a loose range in which neutral exists. So shifting into reverse involves moving the shift lever while searching for the “magic notch“ to allow the shifter to enter reverse.
Since we carefully adjusted the shifter I’m guessing the detent ball springs on the tranny side plate might need to be replaced.
Any comments or suggestions would be appreciated.
Thanks,
Larry
Thanks,
Larry
