Um, the whole point of the Lightning Rod shifters is that there are three levers for the 1-2, 2-3, and 3-4 shifts on the four speed 200-4R. I guess you can use it on a TH350, but one lever would be non-functional. Of course, the bracket that holds the cable to the trans pan and the lever on the trans shifter shaft will likely need to be modified or custom made to fit the TH350.bizerk said:i'm i able to uses the hurst/old lighting rod shifters on a th350?
