I suggest Brad Penn oil. Its high zinc conventional and used by many racers and engine builders. Really have your **** together with dropping in a distributor and getting timing real close BEFORE firing up. I think many failures come from messing around not firing up cleanly and going to 2000 rpms . If you put in cam and used a degree wheel verify the timing tabs while at it. As a note,,,when the 2 dots line up on timing gear, that is NOT TDC of #1 ! It is TDC of #6...a reason why many mechanics try firing up 180* out. So cam gear dot straight up, crank gear mark straight up is #1 firing. Put cover on and line pointer up at about 12* BTD . Once you get the distributor in, rotate base till the points start to open or reluctor and points on shaft align.
. this will get your timing correct to fire up without messing to much around. Another stupid mistake I see even veterans make is not having the carb filled up.If your using a mechanical fuel pump- take a squirt bottle ,,ketchup bottle ,,something and fill the carb through the top vent. Cranking over and over waiting for the mechanical pump to fill the carb is hard on a new cam! Just fill the carb through top. Also,,,make certain the lifters spin freely in lifter bores when putting them in with oil...if there's a little junk, or rust in a lifter bore...that lifter won't spin correctly and will wipe out that lobe in seconds. lower ratio rockers are good on BBC,,,but a sbc with hydraulic most time doesn't need them..unless you really got dual springs,,then removing the inners for break-in is best. Regular 1.250 springs with 110lbs, and 1.5 rockers is mild enough. Hope some tips helps,,,just be 100% sure it's ready to fire moment you turn key and straight o 2000rpms and vary 1800-2200 to vary the oil splash inside.
