I have a 72 Elcamino with 4 barrel Q-jet carb. It idles at 750 in park with pcv connected to pcv port at the base of carb. When I disconnect the pcv hose from carb and hook up vacuum gauge the engine rpm drops to about 630. I then re adjust the idle back up to 750 and adjust fuel mixture. I then disconnect the vacuum gauge and reconnect pcv hose and the idle (rpm) shoots up 900+. Can someone explain why?
