Subframe graph experts (Shine, I would appreciate your input), I can't find a reference point thats the same on each side of the G body frame clip to square it up to a 48 GMC truck. I have measured every conceiveable mark and they seem to be off from the left to right side of the clip.
Can anyone help me with advice on what I can use for a reference point to measure to? On Gen 2 Camaro graphs, I have used the shock tower hole as the reference points, but these holes are a 1/2" different from side to side on the g body clip.
Thanks In Advance,
Don Meyer
We Found A Soluion
Don and I were able to find a solution for finding a reference point. We put to lower control arms on the G Body frame section and used the lower ball joint grease joint to do a measurement front to back and diagonal to the bolt on the rear leaf spring front bracket bolt. We actually got these measurements to within a 1/16th inch. I wanted to post our solution for reference to others who try to use a G body frame graph. The G Body is a difficult donor due to the lack of symmetry from side to side.
Discussion Starter #3
An other comment.....the G body altho not being easy to measure to when doing a graft, is a great IFS because of it's track width. It is 58" compared to the camaro's 61 1/2".
