Please don't yell at me. I have really tried to do my homework on this one but I am just at a sticking point. I have used all the pictures etc. that I could find from the board, knowledge base etc but I just cant find my answer.
I have a 700r4 that I am trying to ID. The number on the pass side of the tranny is TKZ530732. There is not a number identifying the year prior to the TKZ. It has not been ground off. The stamping looks original.
There was, what I will call, a GM bar-coded sticker on the top of the bell housing with large font letters at the top of the sticker, a smaller group of letters and numbers below that and then a bar code. The number, to the best of what I can see is 619mzmy0298024.
On the passengers side there is also the casting mark, and per the Crosley website, that is shaped like a rainbow and flows through the upper cooling line fitting. On the bell housing on the pass side is an MD8 and there is a pressure tap up and behind the servo, roughly where the TV cable connects.
On the drivers side is the 4 pin connector and the pan is square with 16 bolts.
The input shaft is 27 spline and the output shaft is 30 spline.
I sure hope you can help me ID this. I am not sure if it will be a big deal as I go to rebuild this, but it is just driving me crazy.
Thanks for all your help.
