Got a problem with my 89 Silverado. When I go to stomp on the gas it bogs like an outboard motor and doedn't give me full power. In first gear its ok, in second it gets a little worse and in third its just wants to die. Checked the timing and its at 32 degrees, replaced the plugs, checked both fuel filters and fuel bowls in the carb. There is plenty of fuel pressure on the gauges, in neutral there isn't much of a problem its just when its under load
Here is the rundown on my engine:
1970 350 block (no computer)
12:1 compression
solid lifter cam
Holley 750 DP
Full MSD Ignition
Turbo 400 tranny
10" 4000 stall
Thanks in advance
12:1 compression
solid lifter cam
Holley 750 DP
Full MSD Ignition
Turbo 400 tranny
10" 4000 stall
Thanks in advance
