CLICK ON MY AVATAR
I need help taking apart my 67 steering column.I was hoping you guys could steer me in the right direction.Every time I make a hard turn my front blinkers stop working.I think two wires in the steering column are touching each other.How do I start?Do I take the steering wheel off first or is there another way to get in there?Thanks bm
Shop Owner And Troll Hunter
The 67 is a little more simple than the one Bob posted;
Just remove the steering wheel. You will need a puller, then the horn contact ring, and there it is, Remove the actuator arm, unplug it from the harness, remove three screws and pull it out.
Troy
If you don't make mistakes. your not doing anything.
69 SS/RS full custom Camaro 98 ISCA Grand Champion
69 SS/RS BB Camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 SS Chevelle BB conv.fresh frame off
26 T sedan street rod
CLICK ON MY AVATAR
Troy,
What kind of puller?Is it someting I can buy?I've never taken apart a steering column before.Thanks for the help.bm
It's called a steering wheel puller. A parts store should have them.
If you don't have a manual, go to the local library and make copies of the pages you need from a repair manual. It's pretty simple.
Troy
