Hey everyone. I will start off by saying that I am new to this site, so please be gentle with me. Ok, I have a 1996 Chevy S-10. About 4 years ago I replaced the water pump and then about 3 years ago I had to replace the radiator due to a crack in the side. Just recently the temp gauge was getting a little high and it was blowing cool air, so I checked the over flow tank for the radiator and it was full, but the radiator had a little coolant left if it. I also notice a lot of rust colored water when I added some to get to the shop. Note- when I opened the radiator cap, the coolant shot out of the over flow tank, so it should not be clogged. I ended up taking it to the shop and the guy had me replace the thermostat and flush and fill. A pressure test showed that I was not loosing pressure. I also had the hoses replaced. Well, a week and a half goes by and the temp gauge has now started to get high again and the coolant in the overflow tank is full, but no hot air. I do seem to smell a little coolant when I get out of the truck. My heater coil is located in the cab right under the console and I have not seen any coolant leak onto the floor nor smell any coolant inside the truck. Any ideas of whats going on?
Thanks,
cahillnnc
Thanks,
cahillnnc
