Identify this bracket
837 Views 5 Replies 3 Participants Last post by  2old2fast
Hello all,
I have been searching the web for an hour and can not locate something like this simple bracket. Not sure what is it called from the factory. It is a simple effective way to mount steel, rubber or aluminum tube to the frame or fender well. It is shaped like an M with nothing more than a hole in the center for a bolt.
Automotive tire Bumper Rim Automotive exterior Automotive wheel system
t is a
There are a lot of hose separators but they are $$ and need to be drilled to mount to a frame.
Does anyone know what this was called from the factory or know of a source. I can always hit the pick a pul for this one project but would like to be able to order new and different sizes.
Thanks,
Chris
See less See more
1 - 6 of 6 Posts
Never mind,,, The very next page in my last google search gave me this.
Double line clamp..
That made me laugh!
Found the same thing after a 2 minute search.
I cheat!
I use ‘google images’ to find stuff.
I searched for fuel line clamps.
‘google images will show hundreds of pics for reference.
That made me laugh!
I cheat!
I search the images also,,, sometime i feel like google gets my in a loop of the same thing over and over. Especially if i click on something then it keeps giving me more of the same stuff i don't want.
Yupper!
A lot of time it depends what you ask for. A different word or two turns up a lot of different stuff.
GM used those ‘m’ style clamps for fuel lines on their trucks. Easy to find at the wreckers.
Very simple to make which gives you size options & lining with rubber or plastic ...
1 - 6 of 6 Posts
