This is on a 94 s10 frame.
I am throwing the engine back where the transmission was previously and will be notching the old engine crossmember to set the steering box inside it (drivers side) before cutting the frame off in front of the A arms. The pitman arm will be facing mostly forward when driving straight.
I am picking up a (new) manual 525 steering box tomorrow(I need to see if I can fit the old the power steering pitman on it) and the orgional plan was to eliminate the idler arm.
But.
I am looking at the above photo and wondering if I notched the passenger side of the crossmember and mounted the idler 180 degrees(on the crossmember) if that would affect anything geometry wise?
This would allow me to use factory steering parts that are cheap and easy to find instead if fabricating the "cross over" linkages from scratch.
But.
