41 - 60 of 66 Posts
Here's my "Nova" box and cross steer setup. Simple and effective.
Its hooked to this Flaming River tilt column...
Feel free to use whatever column you want... it won't matter.
Centerline
HotRodsAndHemis.com
"Remember, if you didn't put it together with your own hands, its not really yours." - Tim Allen
Discussion Starter #42
drop axle
thanks once again guys, duece, i want to be in that line of cars! Thats an awesome shot. Has anyone used a rack other than the vega mounted one?
The Vega wasn't a rack and pinion, it was a steering box. Probably the most popular ever in street rodding.
Personally I see no reason what so ever to try to use a "rack" in any solid axle front.
Discussion Starter #44
drop axle
I know of the vega box, but there is a rack commonly used that they designed to bolt to a vega box bracket attached to the frame, thanks tho
Its made by a company called Unisteer.
Bolts to the "vega/nova" style mount. Very nice but not exactly cheap. I think Deuce runs one on his 3 Window.
Centerline
HotRodsAndHemis.com
“It's better to go into a corner slow and come out fast than it is to go into a corner fast and come out dead." - Sterling Moss
The shot of my 32 roadster was taken @ the GoodGuys Indy event 2007. That shot was actually printed in Street Rodder Magazine. 2007 was the 75th anniversary of the 32 Ford and GoodGuys had a special get together @ the Indy Speedway for 32 Fords only.
GO HERE to see it on the Street Rodder web page
http://www.streetrodderweb.com/events/0706sr_goodguys_indy_coverage/photo_08.html
The Uni-Steer works great. I have one on my 32 Ford 3W.
Vega boxes are good also but finding a good used one on a Vega is difficult. Buying a new repro quality Vega box is almost as much as the Uni-Steer. :mad: Some of the repro Vega boxes are not very good.
I had converted a friends 32 with a Vega ... over to a Uni-Steer and liked it. SO ... I bought one for my 3W. I have a Vega box on the roadster. It works well also ... but if it ever needs replacing, I will convert it to the Uni-Steer also.
donna hernandez said:
Centerline, I like the way that Nova box looks. What year do I look for to get one?
To the best of my knowledge its an early 60's unit. I don't know for sure as I purchased it at a swap meet several years ago. Its not quite as small as the Vega unit but it is small none the less. Cost me $15 at the time.
Centerline
HotRodsAndHemis.com
"If guns kill people, then...... pencils miss spell words, cars make people drive drunk, and spoons made Rosie O'Donnell fat!" - Anonymous
Discussion Starter #50
drop axle
thanks centerline, that is the one I had mentioned. Nice piece, but as I mentioned, Im curious of a different rack existing that has a more traditional mounting location off of the crossmember. Id like the clearance around the frame that the vega bracket occupies.
If you look closely at Deuce's picture of that unit you'll see it does bolt to the Vega mounting bracket.
Centerline
HotRodsAndHemis.com
"Speed has never killed anyone, suddenly becoming stationary… that’s what gets you." – Jeremy Clarkson
Discussion Starter #52
drop axle
trust me, I understand the vega bracket,I am wondering about another rack design that does NOT use the vega bracket. I am trying to keep that area on the left frame rail clean of obstruction. Thanks again
If the rack is NOT mounted to a frame rail, it must be mounted to the front crossmember :mad: Not a good place to mount it ... because of caster changes when the suspension moves up/down. OR ... You can mount the rack to the axle :( to eliminate the caster changes ... but then you need a sliding u joint to hook the rack to the steering column. PLUS the added weight on the axle adds to the unsprung weight. ADD ... it is UGLY.
DEUCE ... Moderator :thumbup:
The caster has nothing to do with it as it doesn't change. What goes wrong with the rack is when it is mounted so that when the axle goes up and down the arch of the tie rod ends doesn't match the arch of the axle. The distance between the pivot points of the inner and outer tie rod remans the same while the arch of the axle changes the mounting points. Thus you have bump steer.
But the caster never changes, or not much at all and it wouldn't effect how it drives.
TRUE ,,, I was thinking about my reply ... and came back to change it to BUMP STEER ... and had already been caught with incorrect information. :rolleyes: MARTINSR is correct.
Mounting the rack on the crossmember or the axle is still a bad idea IMHO.
It's not a bad idea, it's a HORRIBLE idea. The arch of the pivot points simply aren't going to match those same points on the axle. ONE of them is going to change during movement and you will have bump steer. But the same thing can happen with that Vega box mount, it makes no difference if the rack was mounted to the crossmember or the frame two inches behind or hanging off the frame on that Vega box adapter. The exact same issue exists, are the pivot points on the inner and outer tie rods going to follow the same arch (thus staying the same distance apart) as those same points in the arch of the axle?
The design you are using may be a "rack and pinion" by the design of unit it's self but the way it's mounted it really isn't a "rack and pinion" as we know it, it's simply a cross link "steering box" of a different design.
If it were mounted like that without a tie rod running from left to right spindle and you had the tie rod ends going off the rack to the left and right spindles you would have the exact same issue as if it were mounted to the crossmember. Just to clear things up your "rack and pinion" in your setup is actually a simply replacing a steering box and drag link.
Hotrodders.com moderator
I have been following this thread and all I can say is that the uni-steer is about the only practical rack steering box for an early ford that I know of. the vega type box works fine for most guys but if not having the box up front like that requires then one needs to go back to the drag link setup. Drag link setups can work out just fine if and a big if the length of the drag link matches the length of the radius rods..
I have seen this same discussion many times before and while I am not sure just what the guys in the past have wound up doing for me the works good and steers right overrides anything else..
Sam
Sam, you can run the Vega or like box up at the crossmember with a cross link.
Edit: I just re-read your post and this is what you meant, sorry.
I wish you guys would define your terms because I don't think that's what Sam meant when he said "if the length of the drag link matches the length of the radius rods.." -- that to me describes a side steer drag link. What you show as a cross link can also be called a drag link but that is cross steer.
Correct me if I'm wrong but I believe this is the type steering that's being refereed to as a "drag link" style. In this case the "drag link" needs to be the same length as the "split bones" in order to eliminate bad things happening when the suspension moves around.
Centerline
HotRodsAndHemis.com
"Instructions are just the manufacturers opinion of how it should be put together". - Tim Allen
41 - 60 of 66 Posts
