I had problems with an ACCEL HEI coil burning up my modules until I swapped to an MSD coil. It seems that in order to increase the output of the ACCEL coil, they decreased the primary windings instead of increasing the secondary windings (cheaper). You have to increase the secondary windings of a step-up transformer by a much larger percentage to get an increase in output (step-up ratio) than if you decrease the primary windings by a small amount. Decreasing the primary windings lowers the impedance so that the module has to push more current to create the same voltage, making more heat in the module's power amplifier components.
I was an electronic technician for over 20 years, so I have some experience with amplifiers and transformers. The coil is basically a step-up transformer.
If you have a transformer with 10 windings on the primary side and 100 windings on the secondary side, then it is a 10:1 ratio step-up. If you decrease the primary to 5 windings then it becomes a 20:1 ratio, doubling the output voltage if the input voltage is the same as before. If you leave the primary at 10 windings, you would have to increase the secondary windings to 200 to have a 20:1 ratio. So its much cheaper to decrease the primary windings than to increase the secondary windings for the same increase in output voltage. The problem with decreasing the primary windings is that it lowers the impedance(resistance) of the circuit so that the amp has to push more current than it was designed for, to create the same voltage.
I can't make any guarantee as I don't know all of the particulars of your set-up, but I would bet 50 bucks a stock coil would cure your module problems.
Just my opinion for what its worth,
ssmonty
