Hey guys, i got a 1977 ford f150 with a 351 modified. has had a starting problem since b4 i got it. i got it to start but ran like crap so i checked the timing. it was off so i set it right. lined up the mark on balancer checked #1 cylinder valves were closed. pointed cap at #1 wire it started and ran for like 2 minutes and then it shut down like i shut it off. played with the distributer to fine tune the timing it wouldn't run again for more than 30 seconds. the coil was extremely hot. i replaced it. wont start at all now. the ignition module was replaced by previous owner. the timing seems to be off again. what is an easy way to check timing chain without tearing engine apart. and what else could the problem be
