Hey Guy's have a 69 Firebird that I have replaced the original 350 engine with a warmed 455. I also restored the body at this time. Esentually the car was compleatly apart with all of the harneses disassembled. The car also is a 4spd that I had to remove the interlocking steering wheel satey that basicly makes the driver put the car in reversek in order tremove the key and lock the wheel. Anyway the original Dist.was rplaced with an Hei that was gone through by a well known builder of dist. All parts were new or restored as new in the Hei and then wired with a trigger wire from the harness that piks a new relay to 12v from the battery to module. This starts the car and seems to work better than just powering the dist. Directly from the harness.
Now this is where the isue is the car will shut down when the ignition switch is shut off. The relay is getting back fed wih just enough power to keep the pick relay pulled and keep the engine running. I have isolated the back feed to under the dash and I belive that is may be in the steering colum or the ignition switch itself? I ran out of time the other day but just before I didmy little guyvreached in and turned the signel light on and then all of a sudden tge engine shuts down! WTF! Anyone have any ideas? Ignition switch? Grounding issues??
Sorry about the long winded deal just waznted to get it on throad soon and thought maybe someone might have seen this one before?
I do know this th next restoration will without a doubt will be rewired from scratch! I highly recamend it lol!
Thanks
Thanks
