I'm on the age old topic of ignition wiring. I want to do my F1 Ford truck's wiring in three phases (Ignition, Accesories, Lighting). Attached is the diagram for the ignition wiring.
Ignition: The IGN 12V falls away when I turn the ignition to 'Start'. I was told to add the pink wire to the terminal between the starter and its solenoid to provide direct 12v to the coil when the starter kicks in. Is this ok? There is a 5th pin on the starter 'R' that also gets 12v when the ignition is on 'start' that can be used to provide the 12v but then everything goes through the ignition.
Alternator: The yellow 8 or 10 guage wire goes from the B+ of the alternator to the + on the battery/solenoid. I was told that 30 or 50 amp fuses are too small. Normally on the older alternators you connect the 'charge indicator' to the terminal on the alternator and to the Ignition wire between the ignition and the balast resistor. I have a newer Bosch alternator and I only have a B+ and a 'L' live connector on it. How do I connect the charge indicator and how do I excite the alternator? I indicated the normal connection in the white and black wire.
