Did you bench bleed the new master cylinder? I would try gravity bleeding them and see if that will fix it. Basically, make sure the M/C is full, starting with the RR, loosen the bleeder and let the fluid drip into a pan for 15-20 minutes, tighten the bleeder. Watch the bleeder as the fluid drips for any bubbles. As long as there are bubbles, there is air in the system. Then go to the LR and do the same thing. Next, do the RF and then the LF. Keep an eye on the fluid level during the process and don't push on the pedal. Let us know if it works.79bird said:
