Hi guys, I'm outside priming my new engine in my Caprice. I'm only getting an oil pressure reading of about 38lbs after running the drill for a couple minutes. I'm using a industrial Skill drill so drill speed shouldn't be an issue. I'm using a Crane Cams priming tool. There is still air in last 5 inches of line running into the oil pressure gauge, if that would even make any difference.
Is 38lbs enough to adequately oil this thing? I've read that you should have 60lbs and then turn the engine in 90 degree revolutions, letting the drill run for 3 minutes between each 90 degree turn. Is it safe to stick to that procedure with just 38lbs of pressure.
