i saw a post that eluded to depending on cam your initial timing could even be retarded which made think on my issue. i have a 454 30 over mid 70's vintage, it has a Herbert cam (BH2) duration int./ex. 285 @.050 248 lift int./ex. 629 cam lobe center 110* int108 that's what the sheet states in the paperwork that came with the car. it is a solid lifter, roller rockers. 750 holley, stock HEI, appears to be stock heads do not know if any work was done to them.
it starts an idles fine but would almost die when put in gear so i checked the timing and it was at 0* so i advanced it to 12* and it starts runs and idles great and in gear. i have to check to make sure that 0* is truely TDC with a piston stop so then i will know where timing really is but is not real easy to do on this car and its below freezing in my area in a non heated garage.
once i confirm TDC would you still go with 12* initial timing with the cam that's in it
i was thinking of going with a sniper but not being great with EFI i think i will stick to the holley
