hi, hope every ones doing ok tonight..im taking a turbo 400 trans out of my 1978 1 ton chevy van and replaceing it with a 700r4 to hopefully get better fuel mileage.my question is will it hurt to run in overdrive without converter ingaged? sometimes you need to shut 12v off to disengage converter in town..i know on hills and such you need to drop to drive on the early 700r4..i don't know whether trans will overheat or not..what do you think? also on the tranny wireing can I put 12volts to the purple wire and ground the tcc wire since that's what the computer would do to complete the circuit??I appreciate any advice, thanks
pretty cheap and easy is a couple of kits for this
hydraulic lock up no electrical needed {must remove valvbody to do
or the electric lock up in 4th only just pull the pan
both i have used and they work good but I prefer the hyd kit myself
Yes, you can install a simple Toggle switch etc.. to control TCC Lockup.
TCC Diagram >> http://www.hughesperformance.com/pdfs/HP700-R4.pdf
Lockup Diagrams >> Lockup TCC Wiring
From PATC site:
" If you have a 1982-83-84 car or truck never drive it with the wires on the side of the transmission unplugged. This will overheat the transmission on a long trip. On a 1985 or later it is O K to have the wires unplugged, because of a design change made in late 1984. The only part of this transmission that is electronic is the torque converter lockup. You will still have all four speeds with the wires unplugged. "
700 Raptor 700R4 700R4 Transmission 700r4 700R4 700r4 PATC 700R4 700r4 700r4 700r4 700r4 700r4 700r4 700r4 700r4
Make sure you have the TV Cable installed and adjusted correctly or the Trans will be damaged quickly.
TV 101, 3-Parts >> Bowtie Overdrives | TV Made EZ
http://www.jakesperformance.com/TV_Cable_Setup_Info.html
700R4 Throttle Valve Cable Adjustment Instructions
Aftermarket Carbs = Holley & Edelbrock also require a TV geometry corrector bracket for proper Line Pressure rise.
http://www.summitracing.com/parts/sum-700202
http://www.summitracing.com/parts/sum-700203
