A newbie here. I am installing a 17 gallon top feed fuel cell in my 46 Ford 1/2 ton pick up and am a little confused on how to hook up a Holley 97 Red Pump fuel pump. I do understand that one of the 3 -8an fittings on the top of the tank is for the fuel line, as that fitting has a tube going down inside the tank almost to the bottom. One of the other remaining fitting (also a -8an) is for the return line. Since I am not running a EFI system, that fitting is not required. Question, should I use that fitting as a vent and install a vent filter on it, or cap it off ??? Another question regarding the 3rd fitting ( roll over valve), should that valve have a coiled hose pointed down ? It is also my understanding that the fuel pump/pre & post filters must be located at the bottom level of the tank or lower and as close to the tank as possible. Am I headed in the right direction ??? Thanks, jakes
