Violating consensual reality
I put dual exhaust on my 6 and I have a "heat plate" for the bottom of the intake. I plan to use the small heater hose line to supply coolant heat. The fittings are smaller than the small heater hose. Will this be a problem?
Strummin
Shouldn't be much of a problem if you have a hydraulic supply shop in your area. They should have the fittings and/or adapters you need. Take the fittings you have and tell them what size heater hose they need to fit.
What kind of manifolds are those?
