Hello guys I am making another post so as to not take away from my other post and I was wondering on some opinions here on things. Here is my build 350 Dart shp, Edelbrock performer rpm air gap intake, Dart pro 1 platinum 200cc aluminum heads ported and bowl blended and combustion chambers cleaned up and exhaust as well. 268/272 220/[email protected] 510/510 lift 114 lsa hydraulic roller cam. Scat rotating assembly with forged flat top pistons and 9:1 compression.
As to some who knows I may or may not have an issue with my air gap intake with the current camshaft I have and its a long story and on another post. I am posting this as I know the basics about intakes and flow and rpm rating range etc but I would like to get some more advanced knowledge from guys on here who knows better things about them. Ok I have been looking around and I want to stick with Edelbrock if I can and nothing against Weiand as I have used them in the past with great results but there corner flanges seem awfully thin and Edelbrock seems to have thicker flanges which I like. I won't use other knockoff brands like the procomp aka speedmaster stuff.
Ok onto my question I saw an article on a dual plane intake manifold done in a hot rod magazine and the engine was a 406 small block chevy with trick flow 215cc aluminum heads with a hydraulic roller cam with 232/[email protected] 525/543 lift 112 lsa. Don't know the compression. They ran a Holley 750 Hp double pumper.
That engine made 506 torque and 461 horsepower peak. On the Edelbrock rpm air gap and performer there was not much difference at 4 on power and torque at 504 torque and 470 hp on rpm and air gap 508 tq and 474 hp. So there is only a difference of only 9 horsepower between the non air gap eps and performer rpm. I know the EPS sits higher versus the old Edelbrock performer and I have used an EPS intake in the past with 200cc heads and it worked well but the cam was slightly smaller at 211/[email protected] 500/500 ish lift with a 112 lsa.
My question is what the results be similar in my 350 build if I were to use the performer eps vs the performer rpm intake? I don't race my truck nor do I take it past 5500 rpm anyways as its a cruiser and I always use a one inch spacer on it anyways for clearance for certain things and it always gives me good results. I figure going by the article results I would not loose any torque on what my engine makes and I might loose less then ten ponies on the top end which would not bother me any. My few questions though would the EPS intake give better fuel distribution and better fuel mileage vs the rpm intake and better overall fuel atomization?
The reason is everyone is out of stock and the dates for parts for many intakes keeps getting pushed up and I was able to get an EPS intake on order and hopefully should have it here soon but I am second guessing that it might cost me a lot but anyone with more knowledge on the subject could help me with more info about the more scientific part of things could shed some light and it would sure help. I don't like buying used intakes because I don't know there history and I have gotten used parts off ebay before and have been given lemons and ended up being stuck with a dud.
Like I said I don't race it and am not worried about every last bit of power. Just want this to finally get this problem fixed and if its the cam not liking the air gap and I have no problem swapping out intakes. I won't be changing things out till about March or April but who knows how parts will be by then so I am scooping things up now so I have what I need by the time it comes. I feel if I were to use the EPS intake and loose less then ten horsepower and still have the same amount of torque and yet gain more efficiency overall in mileage and things still be well enough matched then I would feel fine with those results as that outweighs just a few ponies.
Sorry for all the questions and hope to hear some advanced info.
Thanks guys
Eric
Thanks guys
Eric
