Status
Not open for further replies.
1 - 12 of 12 Posts
· Registered
Whats the best way to mount this handle to the door, it will have a full abs panel on the door, so i cant really reach in to screw it from the backside, any ideas?
614521
614522
· Registered
You can take a piece of angle or bend you a 90 on a piece of metal...Bolt the 90 to the door. Cut a slit in the arm rest for the metal to slide in. Then you can run a couple screws down where your hand pulls.
That will make a solid pulling surface. Where the armrest is so long you might have to screw the armrest to the door panel first on the ends and when you attach panel to the door put screws in the pull.
· Registered
Great idea!
· Registered
I didnt use any windlace on this truck...they had the factory rubber around the doors on this truck. The headliner was an abs one piece that the rubber around the windshield and doors holds it in.
Most of the windlace ive used in 30's cars...ive either riveted it on or put wood around the parameter and stapled the windlace to it. you will have to add tack strips if your headliner has to fold into the tack strip to pull it tight.
· Registered
Have you got any posts, you tubes, pictures of any headliner and door panels youve done or tutorials?
· Registered
No, i dont have anything like that...but if you want to message me i can help you any way I can or answer any questions. Probably dont have all the answers but can get you close.
· Registered
You could alter the placement enough to reveal both original mount holes in the door, make a metal plate that had both sets of holes in determined locations, then bolt the arm rest to the door panel with the metal plate on the back side of your abs door card, screwing the panel and plate to the door at the time of mounting the panel.
· Registered
Whats the best way to mount this handle to the door, it will have a full abs panel on the door, so i cant really reach in to screw it from the backside, any ideas? View attachment 614521 View attachment 614522
I believe I have the same armrest in my truck. What I did was on the back of the door trim panel that was fabricated I glued a piece of 20 ga. steel. The armrest was fastened through the steel and the panel from the back. Then when the door trim panel was mounted to the door 2 10-24 countersunk oval head were used to hold the armrest tight to the door, Used rivet nuts for the 10-24 screws. Placed the screws just enough above the armrest so that the screw driver would clear it.
Car Vehicle Motor vehicle Mode of transport Fixture
· Registered
Discussion Starter · #11 ·
Yes, but i would have visable screws still.
· Registered
Discussion Starter · #12 ·
I believe I have the same armrest in my truck. What I did was on the back of the door trim panel that was fabricated I glued a piece of 20 ga. steel. The armrest was fastened through the steel and the panel from the back. Then when the door trim panel was mounted to the door 2 10-24 countersunk oval head were used to hold the armrest tight to the door, Used rivet nuts for the 10-24 screws. Placed the screws just enough above the armrest so that the screw driver would clear it. View attachment 614620
Yes, but again, im trying to eliminate seeing screws but i really like your interior
1 - 12 of 12 Posts
Status
