On my wife's '91 S-10 4x4, there is an intermittent vibration/noise from the front end. Sounds almost like something is rubbing the tire. It seems to be on the passenger's side and I can feel it slightly on the floorboards but it's pretty tough to pinpoint. The steering is not affected by the vibration, and I have ruled out any tire interference. Hitting a bump in the road usually triggers it, and only when the drivetrain has warmed up, or the temperature outside is above freezing.
It started with a brief sound when she'd hit a bump once in a while, I figured it was the mud flap. Over the last few days, it has gotten a lot worse and will sometimes last until the vehicle stops, or hit another bump. The CV boots looked good so I replaced the right wheel bearing with no luck. I was out testing it this morning and the sound didn't come back when I drove it in 4WD. I removed the front driveshaft to try to rule it out and the symptoms returned. She doesn't use the 4WD very often, and IIRC last winter the front diff didn't seem to be engaging (classic S-10 transfer case vacuum switch).
I have two ideas left - 1) brake caliper pins need lube (but it continues to make the noise while the brakes are applied) or 2) the vacuum switch on the T-case is trying to engage the front diff while the vehicle is moving (I'm pretty sure the transfer case is not a shift-on-the-fly unit).
I'm going to head out and try looking at those two items, but I sure am stumped. Anyone have any input?
