i would like to believe anything can be done.but my answer to this modifacation on your c-10 i wouldnt do it.first without the rubber your windshield is about a quarter inch smaller than the opening. if you extend the pinchwield to what would make a safe glass to body bond.your windshield will need a black band around the outer edge to conceal the urithane or butle used. i can't think of a moulding that would look good with this installation.if a glass man say's to you i can do it, he needs the money.i have installed glass without the rubber on chevy's much older with two piece flat glass with the top chopped looked good.C-10 said:Glad to have you. There's definitely some chop top's going on here now and then.
I have a particular question pertaining to doing away with the big rubber gasket and then modifying the structure around the windshield opening to use butyl tape (or caulk) with a nice thin finishing rubber (modern looking) around the windshield.
When the time comes I will PM you about this and maybe start a thread on it.
your chopped nova would be my first.without measuring the opening & the glass i don't know if the windshield can be cut down to fit or not. a glass shop down town would run backwards if asked to do this job. but i cant rule it out yet; i would try cutting the glass down before you try lex-and. remember measure twice and cut once. you will need a very experienced glass cutter that knows what he's doing. :thumbup:geezer69 said:welcome to the forum.can you cut a windshield for this nova.or will i need lex-an?
