Hi to all!
I just finished my 55 BA Powergide rebuild. I did it because it had several leaks but it ran very well. What I did found was the stator inside the converter had chewed something in the past so I changed the entire converter just in case for another I had laying around that looked excellent inside but had evidence of being working loose at least in one of the screw bosses. Now, when I start the engine theres nothing strange the first 5 or so seconds but after that it starts making a rhitmic noise that looks like one hit per rev. Its not a grinding noise but more like something-is-hitting-something kind of noise but not hitting very hard. The flexplate is straight and the trans works good the few meters I moved it. I think it must be the converter because theres not much more moving inside the trans when in park. Maybe when the front pump presurizes "something" it gets misaligned? Only thing I found odd inside the "new" converter was a bearing a little too worn out and that may be the cause of too much movement of the stator paralell to the axle.
What do you people think?
