HOK MC-OO is a cheaper solution for real chrome but it's no easy shoot.
It HAS to be shot over a FULLY cured clear coat which HAS to be PERFECT.Otherwise,ANY imperfection will blow up big time. Your essentaly creating a mirror. Great way to check your fingerprints if you want. Wipe down is critical as well. KC-20 is recommended and for GOOD reason.
I've experimented with the MC-OO quite a bit and used most every type precleaner. Even SPI's waterbase and most all have left wipe marks which were virtually invisable till you spray the first coat. UGGGGHHH...
It is a great GRAPHICS tool and for SMALL areas is great. I would not even attempt doing ANYTHING large such as glass bumpers or large panels.
HOK states in the tech manual that it is for LIMITED use and graphics type work only. It has serious delam issues as your shooting it over a highly polished surface so do NOT expect it to last.
Clearing it is a whole 'nother story. "If" you get the light dust coats sprayed right,you still have 1 big ***** hill to get over with the clear. The "key" is to use a fast flashing clear with multiple light coats. Even using HOK UC-35,You hammer it on and it will turn to your standard aluminum look finish.
I've even seen the HOK training DVD on it and unless you have GREAT atomization,light dust coats and a good clear technique. Don't waste your money. Painting any of these "chrome" paints is an art and requires some "chops" to pull off.
Now that I've scared everyone to death,
If you have the time to try it and $45.00 for 8 oz. Give it a shot.
One "secret" to spraying the MC is to go VERY light with each coat,you want to think black chrome,A little goes a LONG way. A good atomizing gun is a MUST and crank the fluid WAY down,give it plenty of flash time between coats and even 24 hr before the clear is not too long a wait.
