1 - 2 of 2 Posts
In The Knowlege Base I am having trouble finding a guide for my first time running lines. I don't understand the fittings not being the same size as the line (ie, the booster outlet is 7/16, but I was told to use 1/4 line?) Also, do I need the 2 and 10 pressure valves if my booster is mounted in the firewall, above the wheel cylinders? And I'm actually having trouble finding the supplies on the web. I just see full kits from Summit, and they look overpriced. Thanks for any help!
I'm working on my brakes now. Speedway motors has good selection of brake stuff and Godman sells stuff but is little pricey. From what I understand you only need res valves for under floor mounted master cyl. For disc/drum you will need a propotioning valve, either an adjustable or fixed. I have found an older parts store in my town that can get or has lots of the fittings I have needed cheaper than the catalog places. A good flare tool and tubing bender helps a lot. I hope this helps.
1 - 2 of 2 Posts
