I meant to paint cars with?
Which one? The 40716 requires 1/2 that compressor to keep up. That's the gun I have been able to run with my HF 90234 ( discontinued ) compressor which is 10 gallon 5.6 [email protected] PSI.I'm using the cheapo hf purple guns till I can save up for something. better
yes I have like 5 40716&94572 kit...gonna be shooting full carsWhich one? The 40716 requires 1/2 that compressor to keep up. That's the gun I have been able to run with my HF 90234 ( discontinued ) compressor which is 10 gallon 5.6 [email protected] PSI.
The 66222? ( replacement for 43430 ) takes quite a bit more air.
You can paint with one like that with only a couple of problems. It's going to cycle fairly quickly, and quite often. The second issue is...it's a single stage. Recovery time is going to be a little slower, and with that, heat will be one of your big concerns. And you know as well as others do, a single stage compressor generates quite a bit of heat and along with that come moisture. So you'll need to make sure you have a good water trap close to the compressor and also close to the gun. You can get one of the water trap balls that go at the fitting of the gun to trap moisture before it gets into the gun.![]()
