1 - 11 of 11 Posts
Yep, 67-69 Camaro. 70 and up had front steer.
And those aren't stock brakes so you are going to have to do some research to come up with the pads.
You know what, they may be original, I was thinking, the 67-68 had a four piston caliper I am pretty certain but the 69 I believe was single piston so it could be a 69 subframe.
Thanks Guys, that was quick. I am not sure of the stud pattern other than it is a five stud. It has what look like Vintique wheels with two patterns ie 10 holes. I will measure up at the weekend and see if I can work it out. I will do some more research on the 67-69 Camaro route to see what I can come up with. I sent the pics to Real Steel to see if they could help but no reply yet.
Now I need to find out what carb I have on the 305 so I can rebuild it, some old single barrel leaky thing, might be best to replace with a four barrel and a manifold, but I'll save that for another post.
Came with an English MOT but lots to do to pass our Isle of Man test, oh well spanners ahoy!
Thanks again
Discussion Starter · #11 ·
fingers crossed and thanks
Just to update this I contacted Summit with the pics and they confirm it is a first generation Camaro 67/69 so thanks for the help guys. I really hope it is as I am expecting delivery tomorrow of full front end rebuild with bigger sway bar, manifold & carb etc. Time to get busy.
1 - 11 of 11 Posts
