Hey guys, I’m in the midst of building my new power plant. I’ve been coming to the forum to help me through some trouble spots on the build with a ton of success getting the answers I need from members of this forum. So I’m back for more clarification. I’ve got my short block assembled and ready for heads. Im running afr eliminator 220 with Jesel sportsman shaft mounts. First and foremost has anyone install these on a small block check with afr heads before. So jesel provides a replacement low profile head bolt for the center head bolts since the rocker stand will be going over them. Problem I’m having is that the head bolt is too long, so the bolts don’t seat all the way into the head. Not sure if the bolt is bottomed out on the threads or if the bolt is running all the way up to
The top of the threads. My second problem is that I was planning on using head studs. So if I use the head the bolts that come with jesel can I use the head studs in all the other holes or is it an all or nothing type of scenario with that?
