I have a 38 Chev 2 dr, used TCI ifs, CE rear leaf. I found the car rode like a tank. I want a softer ride.The car has 1500 miles now, so springs should be broken in. It had cut coil springs originally and I swapped them for TCI 350lb.These are their lowest rate springs. They will not settle enough so the lower A arm are horizontal, free height 13.5'', installed 11''. I was looking at spring recommendations and Eaton only has one spring that rides at 9'' which is the height I need, a 325lb. The easiest spring for me to get is a CE spring. I installed their 325lb spring , free height 12'', installed 9'' and the A arms sit horizontal. The ride is less harsh but the car body tends to ride with a bump. I took car out with worn out shocks,then installed a new set of KYB GR2 shocks and really couldn't feel any difference. The road I'm driving is wavy and full of cracks and some holes,maybe not ideal, but typical. I'm thinking of trying 300 lbs springs,but my understanding is that front springs should be firmer than the rear springs( which I can't rate).
My rear suspension still bucks on bumps,I tried a ride with no shocks. I'll take out the smallest leaf and see what difference that makes,but don't want the rear to sit lower.My rear springs have settled so they are flat/ no arch.
My question is how smooth can you or do you try to get your ride quality and how do you judge the ride??
