1 - 20 of 53 Posts
So i just bought this beautiful lark. I payed $3,000 for It. I'm about to turn 17 and this is basically my first car. The car is almost all original excluding the wheels and the interior has been redone. It has 79,000 original miles on it. Under the hood is a 350 with a 2bbl carb I believe to be a Rochester? Or whatever comes stock on them. The car runs good but It needs a good tune up. First thing is the car will bog when given to much gas to quick. I'm pretty sure its because of a lack of air. I also checked the spark plugs and they were pretty black which I'm pretty sure is a sign its running to rich? It seems to idle perfectly normal and when sitting if you give it gas it doesn't really bog. I need to figure out how to solve this problem so I can start driving her. Would It just be easier to buy a new holley 2bbl carb for about a $150? I plan on doing an oil change, new plugs, belts, hoses, etc... Please leave me your thoughts on how to solve this problem and any other things i should consider doing to her before hitting the road.
Die standin' up
17, yay, another young man in the hobby.thats how it stays alive. cool. nice car to start with too you lucky rascal.i had a 59 ford for my first car. good luck and let us know how its goin. got any pics ??? we all like to see them rides.
Faith - Respect - Trust
rebuild the carb, put new plugs and wires,have some fun
I agree with Vinniekq2, how long has it been sitting? If your not confident in rebuilding the carb, buying a rebuild or a new one may be the way to go...do everything you said and don't forget about replacing the air filter. If the car is running rich, your getting more fuel than air, a plugged air filter can give you this effect...check that out first.
Congratulations young man and best of luck.
Ray
Music and Hot Rods
Don't forget the points, condenser, cap and rotor with that tune up. Set the intial timing a few degrees above what is stated on the label as that was the beginning of the smogger motors.
Thanks guys. I attacthed a pic of the car. The picture isnt very good. Its not faded at all.
Im not confident enough yet to rebuild the carb myself. I feel it would just be better to get a new carb anyways. But with the distributor i should replace the cap and plug wires? Can you explain more as to what i should do with the timing? The car has basically been sitting for 2 years. The guy would start it up every once in a while and take it around the block.
Beautiful...where are you from, it looks like there isn't any rust...from the picture anyway.
As far as timing goes, if you advance the timing several degrees from factory recommendations ( say factory tells you it should be set at 20 degrees advance? not sure what the factory timing specs are, set it at 22 degrees) you get a bit more power. This is something you could play with down the road, for now it might be a good idea to set it up to run well and enjoy.
Nice car
Ray
under the hood the factory has posted the tune up specs.Basically do that. when you have a few extra dollars,consider changing the points to a none points ignition.Either put a kit in the factory distributor or adapt a GM HEI distributor(high energy ignition) to rebuild that 2 barrel,its actually quite easy,just like building a model,the rebuild gasket set comes with pictures and instructions.Those carbs are known to have the base plate loosen
Discussion Starter · #10 ·
Im from Phoenix AZ. Im not sure where the car originated from but its been in Arizona for a while. The Isn't any rust I could find when examining the car. Shes in great shape and other than the small acceleration problem she runs like a champ. I don't think i wanna buy a new distributor for this motor. I haven't decided for sure yet but I might just build a 455 motor and TH400 trans to swap into It a little later on. So If I'm gonna do that I don't see the point In putting a bunch of money into this motor. Just wanna get It running and reliable.
One thing that I remember from working on a buddy's Skylark.....When setting the timing, be careful...that distributor is awful close to the fan....lost some knuckle skin doing that.
Discussion Starter · #12 ·
Ill be sure to take extra precautions with that. Thanks for the tip.
my KARMA ran over my DOGMA
My first car was also a 72 skylark, nice. It had a beautiful center shifter console, crome plate with the inverted U shaped handle, sweet. The trans only lasted me a couple months :( Last time I drove that car home was in reverse
I would agree, just rebuild the carb thats on it, not complicated, take your time. Good car to learn on, good luck.
Discussion Starter · #14 ·
I may do that. I would kinda prefer just to get a new Holley 2bbl. But i guess ill see what Im gonn do
Young man, don't be afraid to jump in and rebuild the carb. All of us on this board had to learn how to do this stuff. As you learn different procedures, your confidence will build and you'll tackle tougher stuff.
The first thing you'll want to do ----FOR SURE----is to buy an original factory service manual. Most aftermarket manuals are junk, so buy only the original factory publication. It will show you step by step how to rebuild the carburetor and adjust it for best performance.
1972 Buick Repair Shop Manual Original GS/Skylark/Riviera/LeSabre
Discussion Starter · #17 ·
Guess ill just rebuild the carb. Haha Im just skeptical about all the small parts and fine tuning when rebuilding one. Im probably being over dramatic though. Anything else you would reccomend doing since im gonna rebuild the carb?
An upgrade I would consider, after you learn all the systems in your car and how they work, would be to replace your points distributor with an HEI from a '75 to '85 GM car or truck. Points and condensers have been used successfully on every type of conveyance since Kettering introduced them early in the 20th century, but progress marches on and the High Energy Ignition system introduced by GM in the summer of 1974 is a far better system for firing the spark plugs. It has an integral ignition coil and can produce a far stronger spark than the stock points system with a divorced coil, so that a wider gap can be used on the spark plugs. Maintenance is easier also, with no points to adjust or condenser to replace.
First though, I would learn the complete systems of my new car, including how the points distributor works and how to service and tune it.
Remember this.....a carburetor does not need high pressure to operate, so be careful if you have to replace the fuel pump. If the needle and seat "see" more than about 5-6 psi of fuel pressure, they will unseat and allow the pump to blow raw fuel into the intake manifold, creating a tuning nightmare that you may never find. A Carter "Muscle Car" pump will be the best replacement if your pump fails. Carburetors are not like fuel injection, more fuel pressure will not make more hp.
Discussion Starter · #19 ·
How do you adjust the fuel pump pressure level? Are there instructional videos or anything like that you know of? I found out from the previous owner that the cars "bogging" problem was way worse before he had the carb rebuilt a year ago. He said after he had it rebuilt the boggi g was a lot less dramatic but its still a serious issue
So im really curious as to what the problem is here. Is it a bad fuel pump? Maybe the fuel line is clogged somewhere?
When I rebuild a carb, I dissasemble it on the bench. I put down a big clean shop towel, and as I remove parts I lay them to the side , when I get to small parts, I lay them on the shop towel as they wont roll away, and it keeps them plainly in site...helping not to lose them.
I would also say to rebuil the carb yourself. The Kits come with step by step instructions.
Bogging sounds more like fuel starvation to me, also sounds like it does OK when you feather down on the gas, so I would start at the carb.
Fuel delivery could be an issue, so you might want to check fuel pressure as well.
A gauge like this and a few fitting to do the job are relatively inexpensive
Harbor freight sells them ( I hate harbor freight) but this one is good. It will also help you adjust the carb and do other diagnostics on your engine. Quite possibly the best 15 bucks youll ever spend on a tool.
item number 93547 at HF
1 - 20 of 53 Posts
