i have a dilemna...should i keep the old original rear end in the 37 or toss it????? it has two bad axle seals that i need to fix before i can put on the 39 juice brakes......i will be keeping a flat head engine and the wide 5 16" wheels.......i will be keeping the original front end although i may install a dropped front axle.....the only new thing i want to put in is a newer transmission perhaps a T5.....so if i put in a T5 do i have to change the rear axle???? i know i could get the kit speedway sells that allows me to use a conventional drive shaft but what do i do with the radius rods? i saw that i can get an adapter plate that will let me use the wide 5 16" wheels on any newer wheel spacing......also is there any reason newer style drum brakes can't be actuated by the 39 mst cyl? can i just reduce the 1/4" brake line at the end to fit newer style drum brakes? is there another trans option like a 4sp that would be a direct bolt in replacement??? help me ...my brain is going in to overload.....i see why people just get new frames .... thks bob
