1 - 6 of 6 Posts
Hello folks, hope everyone had a Merry Christmas. Want to ask if anyone has expereanced any problem with Keith black pistons, when used in a 351 cleveland 1972, 0.030 over bore .I've been told that there could be a breakage problems, the engine is a mild build compression 9.5 to 1 all new internals except crank, new intake elderbroke performer. and new 650 carb.
The people that have breakage problems with KB pistons are the people that don't read instructions or understand the design/construction of these pistons.
As mentioned, ring gap is a major consideration as is piston to wall clearance.
Pistons:
Stock and 4032 alloy cast hypereutectic, 11% silicon...........up to 450 HP
Aftermarket 2618 alloy forged, 2% silicon ........................up to 1200 HP
The choice is yours.
used the hypers and the icons never ever a problem . and have run 15lbs boost with alky on the hypers in the smallblk. end gap per instructions
The feature I like on the I-Cons is the design of offset pins to limit cold piston slap.For the street,press fit pins are the way to go.
1 - 6 of 6 Posts
