What brackets have you used?
I'm trying to decide between the edelbrock Universal SBC (jegs # 350-8031) one and the holley kickdown (jegs # 510-20-95)
it's going on a SBC 350 w/an RPM airgap intake and 600 cfm vac secondary holley.
the stock (87 monte carlo backet) doesn't really work, and i've had absoluty terrible luck with the cheap (hint) spectre kits.
Member# 3287
A lot depends on which trans you have.
I have a 200R4 and Edelbrock intake and carb. I tried about 4-6 brackets, both GM and aftermarket. None worked. So, I had to fabricate a bracket with a ton of adjustment because the TV cable wouldn't reach the carb linkage.
opps forgot to put that in, its a 2004r
the stock bracket is too close it seems, the throttle is fine, but i can't get enough pressure for the tranny (confirmed by a trusted trans. shop)
