Hey all,
I am in the process of hunting for cams for my turbo engine rebuild and thought I would see if any of you want to take a stab at the selection. If you dont know combo is as follows:
S-10 truck, 3000lb
9 inch, 3:50 gears
TH350, 10 inch converter - 3500-4000 RPM stall
SBC 400 (.040 over)
23cc dish pistons
6" rods
Dart Pro1 heads, 230cc intake, 72cc chambers, 110# springs(dont want to change)
Edelbrock Proflo hardware(Victor Jr.)
Large frame Garrett turbo, 76mm inducer
This truck is primarily for the track so power potential is the ultimate goal. I need to be able to keep around 12 inches of vacuum to be able to tune idle. The turbo I am running is pretty large so reversion is not as much an issue as with smaller turbos.
I want to stay around .500-.525 lift. I also dont want to spend the money for a roller conversion. Hydraulic or mechanical flat tappet is what I am looking for.
I have picked two crane cams in the range I am looking at:
Crane Cams
Product Line Crane PowerMax Camshafts
Cam Style Mechanical flat tappet
Basic Operating RPM Range 3,800-7,200 RPM
Intake Duration 050 inch Lift 248
Exhaust Duration 050 inch Lift 258
Advertised Intake Duration 288
Advertised Exhaust Duration 298
Intake Valve Lift with Factory Rocker Arm Ratio 0.500
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.520
Lobe Separation (degrees) 114
Intake Valve Lash (in) 0.022
Exhaust Valve Lash (in) 0.022
Grind Number F-288-2
-and-
Crane Cams
Basic Operating RPM Range 3,400-6,800 RPM
Intake Duration 050 inch Lift 244
Exhaust Duration 050 inch Lift 252
Advertised Intake Duration 280
Advertised Exhaust Duration 288
Intake Valve Lift with Factory Rocker Arm Ratio 0.518
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.536
Lobe Separation (degrees) 112
Intake Valve Lash (in) 0.026
Exhaust Valve Lash (in) 0.026
Grind Number F-280-2
Let me know what you think and if you have any other cams in mind that might work well.
Chris
S-10 truck, 3000lb
9 inch, 3:50 gears
SBC 400 (.040 over)
23cc dish pistons
6" rods
Crane Cams
-and-
Crane Cams
Chris
