TANGO said:I used a Set of them #083 TPI Heads on this 350 Build . They are 64cc Chambers with 1.94"in and 1.50"ex Valves . Pre-Vortec Performance Heads . I would say they are good Street Heads for a 350 350 H.P Build .
Thanks for that info, I might buy a set off an 87 iroc.
will they bolt up to my gen1 350 intake?
that motor sounds mean.![]()
johnnya said:I think you'll find that L98 aluminum heads have 58CC combustion chambers.
Be careful that they don't raise your compression ratio too much.
Copied & Pasted from the ZZ4 specs on Summits website:
"cast aluminum 1987-91 Corvette L98 cylinder heads. Which have 58cc combustion chambers, 163cc intake runner volume. They have a 1955-86 bolt pattern"
So, yes, your intake should bolt right up....JA.
89t-top said:After you elongate the 4 Center Holes on the Gen 1 Intake to match the 72-degree angle that the Heads are Tapped at it will bolt Right one . Yes I had to do that with my 350 Build . I used an Early Edelbrock #2101TANGO said:I used a Set of them #083 TPI Heads on this 350 Build . They are 64cc Chambers with 1.94"in and 1.50"ex Valves . Pre-Vortec Performance Heads . I would say they are good Street Heads for a 350 350 H.P Build .
