mark53 said:
i put a 1974 454 ci in my '84 elcamino and i would like to get a late model efi system from a u-pull-it savage yard and install it on my 454. does anyone know if this is possible/feasable. i would also like to pull the 350 turbohydro trans and install an over drive auto, like a 700r4. thanks for your help. mark53
Sure, it should be little to no problem if you get the entire set up from the donor vehicle. Chip calibration might be necessary. Will a late 454 donor engine deck height match your 74 454 engine? so the manifolds will fit? and the intake port shape?
Camshaft overlap will show itself if it is a problem with your existing cam. EFI cars have minimal overlap which usually means wider lobe separation angles if you are going to have a decent duration. Remember, EFIs are all single plane intakes.
Street and Performance in Mena Arkansas seem to be the gurus on this.
Wiring alterations must be soldered and use glue filled heat shrink. No cobbling around allowed.
Generally speaking, except for the electric fuel pump and the computer memory, there are only 3 wires that hook to the car's wiring system. Crank, crank and run, and run only....... on the key switch circuits.
:thumbup: go for it :thumbup:
trans should be no problem just adjust that TV cable.
