I have a problem that is driving me nuts (well, nuttier). I've put 3 trans pan gaskets on the C4 that's in my car - all have leaked, always at the rear corners. The worst part about this is that the engine/trans have never run. I've only put oil into the engine (doesn't leak) the diff, (tiny leak at one stud, fixed) and 4-5 quarts in the trans - ALWAYS leaks. This one I glued in place with some spray seal. The TCI pan is straight including at the holes, the bolts are tight and are the flanged OEM Ford. There are no malformed holes or pulled threads in the trans body, there was no gasket material left on the trans or pan and no visible casing cracks.
I have another premium (Fel-Pro) pan gasket, and am about to drain the oil again (yes, I strain and reuse it, it's new). Fel-Pro cautions against using sealer, and by training, I have never used it here either - but this is getting real old and more drastic measures are needed. :smash:
Is there any reason that I shouldn't consider an oil resistant silicone type sealer? If any sealer were to break free, the filter would prevent clogging oil passages.
HELP
Thankfully the body is still off the car and access is good - which is about the only positive
Thanks,
Dave
HELP
Thanks,
Dave
