I pulled out the motor and trans( 79' SBC 350 w/ 305 heads, edlebrock performer intake/cam and carb) from my car yesterday because it has been leaking a lot. i did a full rebuild on it but the gasket set i used was a Cheap ROL kit and i put it in the car almost 2 years ago and it has a Total of 10,000km(6,000 miles) on it. i would expect a 4-6inch round oil stain after parking the car anywhere all summer when i drove it. i have also always had a problem with coolant sitting on the intake mostly after it was sitting for awhile. i always thought it was coming from the thermostat housing and i tried out a different kind and also retorqed the intake manifold and it still seems to be doing it. the Lower rad hose which was new with the engine seemed to have a muddy coating inside, all new coolant was used when the engine was put in. the rad/heater core were from parts cars and im not sure if they were rinsed out before they were put in or not.
i took some pictures of the engine/trans to show how greasy it all got in 1 summer of driving. the passenger side of the water pump and cyls 7 and 8 (head gasket area) looks the worst. i think that the oil pressure line was leaking at the fitting too. The transmission also got to be pretty bad. the engine cross member got it pretty good as well.
was the gasket set i used really that bad or would you say its my fault? i followed directions in engine rebuild books and torqued everything down to specs and used sealant where it was needed.
are cork oil pan/valve cover gaskets ok to use? i bought a full fel-pro kit.
