Update on the 18x36 LeBLOND lathe:
I came home without it, not because it doesn't seem like a good buy but because it's so massive. I drove my old pickup and expected to come home with the lathe. It probably outweighs my truck. The man has the service manual for it and that shows it as weighing 4250 lbs without the motor. My guess is that the motor would add at least another 300 to 500 pounds to that; it's a big one behind that vented door under the head end.
He was willing to follow me home with it *if* I had some way to get it off his trailer when he got here. I don't have any way of getting it off the trailer nor any way of moving it into my garage and no space for it if I could move it.
The massive 3 jaw chuck moves very smoothly to my untrained hand. I moved it back and forth and didn't feel or hear anything scary. The ways appear very flat with a groove running lengthwise that you can feel with your fingertips if you press through the grease. I didn't have a way of doing the test scholman described. All gears were lubricated. The man said he hasn't used it but watched and listened to it running before he bought it. He bought two at an auction and is keeping the small one. He says his brother is a machinist and checked them out for him at the auction.
The saddle moves smoothly all the way up to where the cutting tool can touch the chuck. The chuck has both sets of jaws and each jaw is numbered 1 through 3 in each set. One jaw is a handful. (Say that last statement out loud around someone without explaining anything). I cranked the compound in and back out several times and the backlash appears to be 100 gradations on the dial, consistently. The tool holder appears massive to me. It had two cutting tools stacked in it, one on top of the other. (To reduce chatter on big bites?) Nothing about the saddle or compound or tailstock was shakeable. I jerked upwards and sideways and tried gentle pulls both ways and didn't feel a tick or move. The tailstock has a Morse taper reducer in it.
There is a plate on the side showing 3 columns of gear lever positions and rpms. The lowest shown is 11 RPM and it doesn't get over 100 RPM until the bottom of the 2nd column. The thumbnail test found only the longitudinal groove previously described. There did not appear to be a change from worn to unworn across the ways. I did find a ding about the size of a pinhead where the chain had been, but it was far under the chuck and the saddle never reached it. Another plate down low on the head shows threads per inch and some other stuff. I didn't examine a third plate that's on it.
The man told me he put the heavy layer of grease on the ways to protect them. He said he kept it under roof and brought it out for me to be able to see it from the highway. I passed by his house a few hours after we talked and it had already been put away again.
The ads I saw for this are at
http://www.tractorshed.com/cgi-bin/...lay_db_button=on&db_id=113155&query=retrieval
and
http://www.metalwebnews.com/equipment-sale.html
It has a large box on the backside with big cartridge fuses in it and a disconnect on the side that doesn't show in those photo ads. The button box sticking up from the top has start, stop, forward and reverse.
It would probably be a fantastic deal for someone with a machine shop, but, like I said, it's really too massive for my garage even if I could get it off the man's trailer. I had every chain I own in the back of my truck along with a couple of 8' 2x8's and expected to bring it home. I just didn't realize the size and mass of this thing.
