Just looking for thoughts on timing.
I have a pump gas 540 Chevy (10.2:1), hydraulic roller (.640 lift int & ex, lift is .243/.249 @ .050, 112 LC), mechanical advance only, 707 HP at the crank on the dyno per the builder (crate motor).
This is in a 3400 lb car with 355 gears, converter flashes at around 3500.
I know this question can have dozens of answers and there are endless variables, just looking for general recommendations on initial timing and where full advance should come in.
Right now I believe initial timing is at around 12 degrees, total timing is around 32 and full advance doesn't come in until about 4000.
I recently bought the car and based on several discoveries on the build, I have doubts about their expertise.
I feel a shorter curve with less total advance (more initial timing) would clean up the idle a bit, but maybe I'm wrong. Reaching out to others that may have a similar combo for experienced advice.
