Hi all new member hope someone can help.i got a lincoln 135t and it worked 100% up till now.well heres what happened welding one day and the feed would start and stop for no reason.well i let it cool down thinkin it might be getting hot,i started it again and the feed stopped totally.ive looked online about problems and mine is doin **** others do not mention.i took out the gear box and motor assembly and check it if i hit the motor it would start running fine till i let off the trigger then it would just hum.well i bought 2 12 volt dc motors and they did not run worth a dam,slow and no power,i checked the power from the motor wires and i got 14.75 volt if the wire speed is turn up the antire way if i turn it down the volts decrease like normal.now is a 12 volt motor not enough?what voltage motor do i need?bought a JOHNSON motor(the same manufacturer as it had)johnson told me it was a high torque motor and it didnt fun worth a dam.please someone help
