I would emagine having linex sprayed is fairly expensive. It is done under hight p.s.i. Can it be brushed on , or sprayed on at home? How effective is it if not done under high p.s.i.? Thanks
Slider in Wa.
I am not sure exactly how much but I have heard it cost between $300.00 & $600.00 depending on color and size of the bed. I have used a spray in bed liner made by the Marson corp that only comes in black but sprays well and adheres well.
I did two myself in my garage. LineX is fairly expensive so I looked into other companys. I used a color matched liner in my S-10 from Eastwood with a cheapo spraygun from Northern Tool 30 PSI to spray it nothing crazy. I also did a roll on liner from Eastwood in my Jeep. They were both easy to do and inexpensive. Just do some research and good prep is key.
Slider, in my area, a complete PU short bed is around $400 bucks for Linex or Rhino. My two 36 Ford Running boards cost $80 (sprayed all the way around) In another post, I added some more verbage. Get back if you want more details.
