i'm very sorry; i should have been specific: (why do i do this?)
1) i posted the LO5 350 because the (i ASSume?) pistons/rods and crank(not exactly the crank but i ASSume they are both cast) are exactly the same as a 4.3 v-6 and the specs for the LO5 are more easy to post:
But the actual engine i propose to use is:
LB4 4.3 v-6 i can't find the specs online, it may be similar to:
GM GOODWRENCH 95 TRK 4.3L
www.jegs.com
Anyways, the LB4 is an "earlier TBI" engine, i THINK similar to the LO5 except the 4.3 has a roller cam. But i THINK they would both have similar if not identical pistons/rods. The crank on the 4.3 is probably actually weaker than the 350 due to the split disk design of the 4.3? But i ASSume they are both cast?
i want to use a vortech centrifugal supercharger.
i should have phrased the question as : Would the boost required to have the engine put out approx 300 hp be harmful/stressful to the pistons/rods and crank on a regular basis?
a) The goal is run in the 11.7-11.80 range and the car is going to be fairly light---chevette or monza and under 2200 lbs, so i feel 300 hp should do it?
b) i think the block can take 300 because Chevrolet even said so in the chevy power manual, and the syclone was 280 hp with this engine block and you know the factory was being conservative.
c) Why not just do it the easy way and plop in a 383HT? It's cheaper, more fun this way; i already have a running 4.3.
However, 383 is still on the table.
Sorry for the confusion, i will try to be more direct next time.
