I have some ARP cam bolts and oil pump stud/nut.
The instructions for my Comp Cams timing set says to use Loctite on the cam bolts, if you aren't using a lock plate.
I thought it was kind of odd that the lock plates for roller cams always seem to have metric bolts...
So I was going to install the cam bolts with Loctite, but when I looked at the ARP site they only have a link to General Torque Specs, which isn't application-specific, it just shows torques based on bolt diameter and says to use their Ultra-Torque thread lube.
I'd assume that you wouldn't be using thread lube and thread locker at the same time...
So what's the consensus... lube or Loctite? Cam Bolts and Oil Pump Stud/Nut...
